Thanks!
Does anyone know if there are any that are PWM-free?
The 750$ Crossover 30X uses semi-glossy AG but suffers from the same obvious overshoot ghosting as the Dell 3014 and lacks an sRGB mode so you will be stuck with the over-saturated and inaccurate wide gamut colors in games. Color management support is required to get proper colors. The CCFL back-lit options all use the same grainy AG. The HP Z30i is the only semi-affordable, semi-glossy, overshoot ghosting free 30" but it is a rip off (1300$), has mediocre color presets and lacks an sRGB mode.
The 2400$ NEC PA302W is the only decent 30". 30" glow far more vs. 27" when viewed from less than 4ft. The size advantage 30" offer is lost when one sits far enough away to reduce the black destroying glow.
I suppose the BenQ BL2710PT is my best option?
