Koolance RAM Nozzle Type 0?
Arcygenical
Does anyone know if there's an O ring on the left side of this fitting?
http://www.koolance.com/water-cooling/product_info.php?product_id=623
You can see the red O ring on the right (female receptacle) side of the fitting by the threads, but due to the angle of the fitting, you cannot see if there's one on the left side (the male part) by the threads.
If you open up the manual from the link you give. You can barely see the red O-ring on the inside the female part.
So you have O|--- O|O===
So on two parts there are 3 O-rings. Hopefully the above makes some sense and not as horrid ascii porn. Check out the manual they link to, LOTS of pictures in it.
Ooh, how'd I miss that manual... It's grown like, 5 pages since I checked it 3 days ago!
Good to know... I don't have to use the bitspower fittings now, shaves an extra inch off my custom build :)
Hehe, I only knew cause I looked through the manual the other day because I was interested in how they worked. :D
