Koolance PC2-601BW
Only use Koolance blocks with a Koolance system. Using high performance blocks would not work well.
Hence the word high performance. Koolance kits only use Koolance blocks. Koolance is a mid level WC solution. If you want to buy the parts seperate then just make your own kit and put it in your case. Better performance and cheaper too.
corsair hydrocool is the only one i know of for under 200 dollars, besides that 98 dollar thermaltake aquarius. but who knows how good either system is
