Koolance PC1 help.
invalidbuffalo
A friend gave me a Koolance PC1 water cooled case with a dead PSU. The pump connects directly to the PSU through a special three-wire connector (green, white, and black) I found green to be ground with a continuity check, but I have no idea what voltage the pump uses. Any help would be great.
...and BTW this is not for my sig rig.
UPDATE: It's 110V
Try this PDF. If this isn't helpful give Koolance a jingle and ask for tech support. They are very friendly and helpful.
