I recently flushed my koolance system after having the same fluid in it for about 9 months or so and I had noticed my temps rising a bit and the general water level decreasing.
I ran a little bleach in there to kill and organtic growth that may have come about then used a mixture of 4 capfuls of water wetter and then filled the rest with distilled water.
My temps are still higher than where they should be mbm reports 42 - 44 deg under load when it should be closer to 35-38 under load.
Should I flush again w/ a different mixture or go out and track down some of the offical Koolance fluid
