Has anyone had any luck interfacing the Koolance flow meter with the Aquaero or that other one made in Europe?
I think arcygenical is using one of these in his newest build, not sure what he is connecting it to though, check the worklogs forum.
I have used it with the Aquaero and works fine.
Anything that receives "rpms" can interface with this particular flow meter
Any particular model or all of them?
Looks like the interface board sends mL/minute out on the RPM wire so any fan header that has three pins and can report RPM data can read the flow from this. You could run it off from your CPU fan header.
