Koolance arrived, need help!!!
Zeke
Well, my het blocks arrived today. I have 3 questions.
1.The GPU cooler came with some little tiny pipe-shaped things, I suppose for mounting the cooler, am I going ot have to mess around with those things to attach it to my Radeon 9800 Pro? If so, how difficult is it?
2.The CPU cooler said the temperature probe should be inserted in this specific area which is clear, but I don't see the probe anywhere, it's not in the box or anything, unless it's under the tape on the bottom of the CPU cooler. I ordered the case and the EXOS itself from Frozencpu and it hasn't arrived yet, is it possible the thermal probe will come with that?
3.The hard drive kits came with a HUGE packet of some white goo and some tan goo, what are these for and how the heck do I use them? ANy help here is much appreciated.. MUCH
the temperture probe probobly will come with the case and the rest of the koolance unit.
the white and tan goo is some stuff you suposed to cake you hdd with to get better heat xfer
I put both on? Or mix them together first? or just use 1 or the other? I'm confused...
Originally posted by Zeke
ok, so the temperature probe will be coming with the case?
no..the temperature probe comes with the koolance unit.
and as said before, there is plenty of documentation on the koolance site and lots of reviews that show how to set it up.
k, I was only trippin about the temperature probe, but it's cool cause it'll come with the unit. Thans guys. Also, one last thing, is there any orientation for the ram sinks? or they just go on any direction?
that i have no idea about, if the heatsink fins are symetrical i dont think it would make a difference but who knows. my kits coming on monday so ill let you know how i put mine together.
