koolance + a8n-sli deluxe
crazjayz
Hey guys,
I'm planning on building my first water cooled system after not settling with massive amounts of fan noise for some time now. I decided to go with the koolance setup and I was wondering which of the koolance coolers for mobo's are compatible forcooling the a8n-sli deluxe northbridge? Finally, on top of that, is cooling an Athlon x2 4400+, geforce 7800 gtx, mobo northbridge, and 4 harddrives a problem with the koolance pc3-700 system (integrated into the PC3-724 BK, which is the Lian Li series V case with the pc3-700 cooling system)?
Thanks!
- crazjayz
you need the low profile koolance nb sink, the one they discontinued and then started back up after discovering it had new uses
Well, I have the PC3-720BK. I've got 3/8" tube running from the rad to cpu to vid card. Then it splits to two 1/4" hoses and one goes to a hard drive and the other to the northbridge and then back together into 3/8" tubing to the reservoir. If you plan on doing any overclocking your probably not gonna get much out of it with those hard drives. If your gonna run stock speeds then that should be good enough. I know that the hard drive coolers do pull off quite a bit of heat so with four of them you aren't going to have any overhead for over clocking.
The next challenge is the fact that the 700 series is 3/8" tube while most of Koolances waterblocks still use 1/4" fittings. IMHO you should go with 3/8" block for the cpu and video card.
Here's the CPU block I have: link
And here's what im planning on running for my soon-to-be 7800GTX: link
As for the hard drives you'll have to use the 3/8" to 1/4" splitters to get those to work.
But I will tell you that the 120mm fans run dead quite when it's at idle or not workin very hard.
I also have that same Mobo on the way but haven't gotten it yet so I cant comment on that.
FWIW I have NB and HD cooling in my loop now and plan on taking it out simply because those parts just dont get all that hot. But thats completely up to you.
I will say though, that your gonna have a lot of hose running through that case when you get done with it. Make sure and post pics when you get done!
Hoobie :D
This will soon be moved to the watercooling forum when some mod sees this post. :) Anyway you might see some good ideas for your project at the following links:
Feeding Frenzy
Koolance-DIY Hybrid
New Koolance Exos model
The new Aqua Computer discussion thread
Also check out my homepage for some more Koolance action :D You will find a lot of good information in the AC threads in the watercooling forum as Koolance shares some similarities with Aqua Computer gear. You can also use AC waterblocks with your Koolance Exos without any problems at all. If fact I seem to recall that someone recently used a lot of AC gear with their Exos.
