timberwolf5480
- Jan 18, 2006
Thats a great setup you have there, I like how you used rod to stack the mobos on top of one another, I have a few questions though. In your pics, it appears that only the top mobo has a 20 pin atx power connector, I can't really see very good in the bottom mobos, where the power cables are. What I am asking is, did you have to use separate power supplys for each mobo, or is there a way to piggy back off of 1? Actually, what did you use for power?
Any info would be appreciated, as I plan to start getting hardware to make my own farm, and I like your layout, in the way they are stacked like that.
Thanks
Thanks
