Known issues with 8GB on 680i ?
rabident
Are there any known issues on this? I have 4 x 2GB of G.Skill DDR2 800Mhz. Any 2 sticks work, but 3 or 4 sticks are unstable. It doesn't matter which sticks I use, or in what slots I put them in... it just won't run stable with more than 2 sticks. I boot up and usually bluescreen during Vista startup. Sometimes I can login but then it just locks up at the desktop. Pull a bank of either 2 and I'm back to 100% stable.
It's spec'd at 1.8v - 1.9v. I tried 1.9v and 2.0v. I also tried relaxing the timings from 5-5-5-15 on Auto to 6-6-6-16. No overclocking. Stock/Auto settings and coolers. Nothing makes a difference. I can play Crysis for hours with either set, so I think the modules themselves are good.
evga 680i
evga 8800GTX
corsair 620w
Dell 24"
vista 64
Using an EVGA 680i with 4x2 of GSkill DDR2 800 and Vista Ultimate 64 and the same power supply with no problems.
Are you fully patched? Do you have the most current BIOS installed?
Try running Prime95 and MemTest86 on each stick to ensure they are OK.
I just ordered some parts to build a new computer and ended up ordering both a 680i motherboard and 4GB (2x2gb sticks) of the G. Skill DDR2 800 ram which I assume is the same you're talking about. I was going to go for 8 gigs, but after reading some of the reviews on Newegg, I stumbled upon someone who had a similar complaint and the manufacturer response was:
Manufacturer Response:4 sticks of memory on 680 or 650i motherboard might have issue. we don't recommend install 4 dimm on nvidia 570,590,650, 680i chipset. however, 2 sticks or 3 sticks are no problem whatsoever, thank you
So for now I'm only going for 2 sticks because I don't really feel like dealing with any issues involving 8 gigs when I honestly don't need more than 4. I've seen some people saying they can get 8 gigs using this memory on a 680i but there are some who can't. To answer your question though, it does seem like there are some known issues with 8GB on a 680i. Maybe it's just luck of the draw?
I tried 2.1v and put a 7,000btu portable AC blowing on the M/B and it works now. I played Crysis for 4 hours last night. I still need to test the modules, but it's a pain. I'm on P26 bios which I think includes all the stability fixes. Last time I checked, the later releases just added features & support for new processors.
Crysis runs noticably better with 4GB vs 2GB, mostly with level (re)load times. I wanted to have it precache the whole level into RAM, but it ran out of memory with 4GB, so hopefully it will work with 8GB. Other than that I got the extra to use as a RAM Drive.
Make sure you have ALL of the patches and memory patches from Microsoft if you are trying Vista 64.
