Klipsh ProMedia 2.1
dapcwiz
I have a set of klipsh promedia 2.1 set of speakers... and does anyone know how the *&@# to get the grill off this thing? I tried opening the metal panel on the side, but all I can see is the bottom end of the screws hold hte sub... but there is no apparent way to remove hte grill. I dented it slightly and sometimes when the system bumps really hard, the area aroud the cone of the sub taps the grill and makes an annoying noise... I'm not turningh it up for now... but I woudl really like to get this thing off so I can take out the dent. Any help would be greatly appreciated! Thanks! :confused:
I believe the grill is attached somehow on the inside of the sub enclosure, which would require you to open the entire thing. I would never do that unless I had done it before.
Is there any way to can use something similar to the car dent removal kits where an adhesive is applied and you pull out the dent fron the outside?
Lace loops of fishing line through the holes of the dented part of the grill and gently pull on it, bending the dent back out?
