Klipsch THX 2.1
Nice, but i just got my Logitech Z-2300 2.1 yesterday and they sound AWSOME! Although i have never heard anything better, so............... i tryed to listen to the Klipsch at best buy, but the speakers werent working and then i tryed CompUSA but there set was all crakly and stuff, most likely been used to much. But i like these Logitech, they're nice for me, and i got them at newegg for $50 less than the klipsch (shipped)! But i bet those sound WAY BETTER than your old creatives! Good Job in upgrading! ;)
I had the Klipsch 2.1s before I had a problem with the cables, so I upgraded to the 5.1 Ultras. The 2.1s are great speakers though and quite compact compared to these 5.1s.
Klipsch ProMedia 2.1 and the GMX2.1 are great little inexpensive speakers.Pretty much all PC speakers Klipsch makes are of very good quality save for the 2.0 Ultra.
I used to have the Klipsch 2.1's. I had them for a couple of years and then the sub went out on me. Now I have a set of z-2300's. I'm really liking them. I'm much more impressed by the sub on the z-2300's than I remember being with the Klipsch. If these z2300's go out, I dont think I'd get the Klipsch 2.1's again.
i liked the satellites on the klipsch 2.1 setup, but the subwoofer couldn't go loud enough for me before it started farting.
My son uses the GMX 2.1s and they are really nice. Hes had them for over 2 years with no problems except blowing a couple of fuses. I cant explain why and have tried to figure itout. I just keep a good supply of the fuses around just in case.
I have a set of the Promedia 5.1....I really like them alot too. The sound quality is very nice. I have Klipsch sound all over my house for that matter, I also use the reference series for my home theater setup. I must admit none of the speakers has ever failed. The amps in the Promedia have had some issues over time but fortunately Ive never had any with my current set-up.
Klipsch also has excellent support if you need them. :D
