Klipsch ProMedia 4.2 Wiring Diagram Help
les_garten
Hello,
I have a few sets of ProMedia 2.1s. There was a way to wire them in a 4.2 arrangement. I cannot find the DOC/PDF for that. Does anyone have that document or remember how to do it?
Thanx!
Les
ashmedai
Hook the first one up to the front and the second up to the rear of your source?
les_garten
I don't believe that's how they hook up. They were made to do 4.2 off of a Stereo Card. There is a doc for it, I just can't find it.
ashmedai
Hmm.
Well, if you google "Klipsch Promedia 4.2" this is the first link:
Klipsch ProMedia 4.2 System
Then if you click the link for the Global Manual PDF and go to page 14 it has a wiring diagram that says basically what I posted on #2. Are you sure it's not that?
les_garten
Hmm.
Hi,
I looked at that DOC hours ago and gave up after all the languages started chaging and never got to page 14, thanx!
ashmedai
Yeah, it's multilingual. But I went up to page 16.
Also, it was apparently scanned by an idiot...
les_garten
Heh! Thanx! I went down to the Asian characters and figured it was all the same and gave up.
Thanx Again!
