Klipsch Ifi Sub
Drunken_King
Hello everyone. I just bought the Klipsch Ifi like a couple days ago directly from Klipsch. I received them today and was excited to use it with my computer. So I hook it up and I take my Promedia 2.1 set and set it aside. I fire them up and started listening to music. Satellites output much better sound compared to the Promedias. Now the sub, I had to set it at max to be able to hear it while the Promedias not even half way through and it was loud enough. Why is the sub from the Ifi's so quiet? I did notice though that it goes MUCH LOWER than the Promedia Sub. The sub is in the same placement as the Promedia sub which is on the right side of my desk. Is placement more critical with this sub than with the Promedia?
Also whenever I hook them up to my Xbox 360 or I set the volume on my soundcard on Max, then they start to pop even at low volumes. Any Suggestions?
Another question is can I hook-up my Xbox 360 to my Line-In port on my computer and have the sound output it to the speakers by the sound card?
Yes on the line-in question. Guessing you'll need a converter for the 2 rca's to 1/8 stereo rca jack male. That'll go into the card, you might have to inable the line-in on your drivers.
Yes thank you. I enabled it in the drivers and now i regulate volume of my 360 on the computer which stops the popping.
