Kitchen Table Uses No Electricity to Regulate Room Temperature
CommanderFrank
Cat Can't Scratch It
No, it’s not the infamous 10K desk, but it is a functional heating and cooling apparatus in the form of a desk. It’s called a Zero Energy Furniture table and its capable of reducing heating requirements by 60% and cooling by 30% without the use of electricity. I guess that makes this table a hot item while still being cool. :D Thanks to Forum member Germanium for the linkage.
Guess these French boys don't believe in the law of thermodynamics. Yeah yeah they have a "phase changing material" so there's a few more degrees of freedom there. So when it's warm it'll absorb energy then when it gets slightly less warm it'll release it, which you'll probably not want it to do because you cool feels nice after a warm day.
Those energy claims are ridiculous. It uses a wax to absorb and release heat. Unless you're taking the table out somewhere to heat up or cool down, it's not going to do much besides slightly shift the rate the room warms up or cools down. You could do the same thing with a slab of concrete. The room temperature is still going to warm or cool with or without the table.
... which is why this is being posted on Business Insider and The Daily Mail instead of Scientific American. lol
Only problem is when you want it a bit warmer or colder, it cant do that.
I find the temperature I want my room at varies throughout the year and is also dependent on what I have been doing.
No exercise, warmer room.
After exercise, colder room.
And people have different preferences too.
I would like to know what exactly this magic "phase changing material" is & how it's thermal properties differ from anything else in the room.
The concept has been around forever. My fireplace does the same damn thing. It act as a heatsink/coldsink. I can have a fire in the winter for a day & then not have to use anything to heat my home for 2 days after.
This is stupid. Filling furniture with paraffin and expecting it to do anything more than an insulated concrete slab is straight BS. Even with the thermal mass of a slab you won't save energy. It can reduce the swing in temperature. If this kind of thing could actually keep cool enough long enough it would cause condensation.
I'm constantly amazed by how little 99.5% of the population knows about energy efficiency.
not exactly, this thing is kind of like using an ice+water bath to maintain a temperature of 0C except here the phase transition temperature is apparently 71F. (think latent heat)
as to its efficacy... who knows
I bet the cost of the desk to consumers will be sooooo far beyond reasonable that it won't even matter if it works or not... lol
Yeah just adding a bit of thermal mass to your house wont make a bit of difference.
Now if you build your house with a lot of thermal mass, you know a mud house so to speak, then it makes sense.
This should work like the PCM based drywall, if you happen to like 71 degrees. It's funny, i've tried to buy PCM paraffin, but most chemical supply houses treat you like a terrorist when you try to order the the formulations that have a specific melting temperature (most of the ones you buy easily have a melting point that's much too high). They won't ship it to you unless you can prove you're a university or a company. And it's treated as a dangerous, flammable liquid for packaging purposes, unlike apparently mineral oil and those high temperature paraffins.
Start a company, it's easy. I started one just so I could order wholesale computer parts back in the days before buying computer hardware online at wholesale prices was a thing.
Its a heat sponge, and the only way this would make any sense is if your dwelling experiences rapid temperature changes, say very cold nights and very hot days, which is the case in some low humidity desert like environments for example.
Then it would act as a buffer on how hot or cold the room became, but there's surely not enough material there to make a significant impact. You'd likely need to do all your walls in the stuff.
And really, you know what heats up and cools down the slowest but has plenty of surface area in every room? The floor... so build on a big concrete floor, and voila. This is common practice, where you highly insulate your walls, and allow for a huge thermal mass in the form of a ton of concrete the house is built on.
BTW, the same thermal mass concept is why its smart when you expect there might be power outages (say if you know a really bad storm is coming) to put a bucket of water in your freezer and fridge compartments (with enough expansion room in the freezer obviously). The water has a huge thermal mass, and when the power goes out will help keep the temperature steady for a very long period.
Its not bad, i did a calculation on the amount of energy stored per kilo of paraffin undergoing phase change and its viable. With a 71 degree transition point they don't need huge temperature swings to make a difference, the wax will melt anytime there is net energy increase in the room above the transition point, and having the mass above the in the middle of the plenum is good placement. Its not necessarily the best use of your money but then people who build super energy efficient houses with outlet based zigbee monitors and full automation, vacuum insulated panels etc arent making decisions based on RoI but to reduce carbon emissions. Every kwh or btu matters and if they're willing and able to pay 5x for construction material, good for them, supporting the tech will help with the trickle down effect. Our solar panels wouldn't be the price they are now if some companies didn't purchase heavily when they were expensive as a public service gesture to provide cash flow.
Likewise, manufacture of these PCM microbeads wont drop until there's a market. If they can make these things fashionable, id rather have rich folks put these all over the house than that third ferrari. Makes for more interesting dinner conversation too.
Not a bad idea, i need a company that focuses on 3d printing of thermal management technologies for the computer and consumer entertainment industries. So i can write off all my hobbies as startup research expenses, yeah!
Hope you don't have a house fire. If that shit melts and lets loose, you'll have a not so small petrol-chemical fire on top of the residential building fire. Hope the local Fire Department is equipped.
Well that's the rich-guilt and feel good nonsense that gets sold to them, and really has no impact. After all, if they really wanted to reduce their carbon footprint, they would simply consume less, but they have such high salaries that their consumption is through the roof and consequently so too are their real carbon footprints. Your average schmuck living in an apartment building likely has the smallest carbon footprint, and I'm sure so called "green conservationists" like Al Gore are hundreds if not thousands of times higher (considering how often he flies jets private and first class public):
You cannot stop this.
The Last Question said:
The story deals with the development of universe-scale computers called Multivacs and their relationships with humanity through the courses of seven historic settings, beginning in 2061. In each of the first six scenes a different character presents the computer with the same question; namely, how the threat to human existence posed by the "heat death of the universe" can be averted. The question was: "How can the net amount of entropy of the universe be massively decreased?" This is equivalent to asking: "Can the workings of the second law of thermodynamics (used in the story as the increase of the entropy of the universe) be reversed?" Multivac's only response after much "thinking" is: "INSUFFICIENT DATA FOR MEANINGFUL ANSWER."
saying something like this is totally unfair, now I don't want my next card to be an amd card...
But yes, exactly. :p
To go with your example, what would happen if the cooler, CPU and water all started out at the same room temperature (as in no ice added)? That's exact analogous the the situation where the table and wax inside it are in equilibrium with the room temperature. There's only some net benefit in your example or how the table is being advertised if heat is added or removed in the medium (with ice or heating or cooling the wax) to change the initial conditions. Then the water will heat up slower or the table will absorb or release heat if it differs from the room temperature. Otherwise, the table acting the same as the floor, wall and other furniture in how it pulls and releases heat when a differential exists (although the wax's phase change will cause that to happen in a less linear fashion).
If this is so revolutionary, they need to be selling this at the same price if not less than existing tables people buy out of Walmart.
Otherwise, the cost for the table makes it an unjustified expense and therefore dominantly a product for cosmetic-sake with bullshit marketing.
