hypernikes
- Aug 26, 2002
I ordered my Kingwin AWC-1 WC kit yesterday that I plan to put in my Shuttle XPC system and I'm just wondering how I should set it up. Since kingwin kit is a rebadged evercool kit, I was looking at the evercool website and looked at the instructions. With their instructions, the kit should be configured like this:
(5.25 Pump/Rad) ---> (GPU Waterblock) ---> (CPU Waterclock) ---> (2nd Radiator) ---> (5.25 Pump/Rad)
Wouldn't this be better? This is my first watercooling attempt.
(Pump/Rad) ---> (GPU Waterblock) ---> (2nd Radiator) ---> (CPU Waterclock) ---> (Pump/Rad)
Basically there would be a radiator between each waterblock and the water would be cooled before each waterblock. Or is it more efficient to cool the water with 2 radiators in a row? Have any of you with this wc kit experiment with the ordering?
If I mount the 2nd radiator/fan in the back of my shuttle, there might be enough room to put a more powerful pump inside my shuttle. The main con about this kit seems to be the lack of power (gph) from the pump. If I do get another pump, it would be the CSP750 which should be small enuogh to fit in my shuttle. I was thinking of maybe using it with the kingwin pump.
Would a 2nd pump add more difficulty trying to bleed the system of air bubbles?
I was thinking about possible configurations with two pumps. If I make modifications to the inside of the 5.25 bay, I can make the pump and radiator inside the bay, seperate items by adding in some y connectors.
........................................ ---> (5.25 Pump) --->
(2nd Rad) ---> (5.25 Rad) ---|..............................|---> (GPU) ---> (CPU) ---> (2nd Rad)
........................................ ---> (Ext. Pump) --->
Or:
........................................ ---> (5.25 Pump) ---> (CPU) -->
(2nd Rad) ---> (5.25 Rad) ---|.............................................|---> (2nd Rad)
........................................ ---> (Ext. Pump) ---> (GPU) --->
Which one do you think would be better? Or are there other possibilites that I haven't thought about?
Or:
