zero2dash
- Oct 23, 2007
On sale again, online and in store. Fairly hot deal (IMO) if you can pickup.
http://www.microcenter.com/single_product_results.phtml?product_id=0325743
Just picked up 4 of these to fill up a Nxzt Gamma build I'm doing for a friend; quiet and cheap was the objective. $13.09 out the door.
They're definitely quiet; obviously only being 950rpm, they're going to be quiet. The airflow spec is pretty close; they push less air than my S-Flex SFF21E (@ 49cfm), but I'd say (putting them side by side and feeling the air on my hand) they could possibly do their rated 40cfm.
Normally I'd order some Yate Loons from Jab-tech but these were cheaper to buy and pickup in store than pay for 4 Yates shipped from JT.
They will make very good case fans for either intake or exhaust; I don't know that I'd put them on a heatsink with any real high expectations (versus a Yate High, an S-Flex F/G, or a Noctua P12)...but if you need cheap case fans (to use now or throw in a drawer as a backup), well here you go.
