Kingston ValueRAM voltage question
JinxCA
RAM: KVR800D2N5K2/1G 1GB Kit DDR2-800 PC2-6400
The question I have, is that I've been overclocking my e6400, currently at 2.8 with a 1:1 ratio.
FSB is at 1400, and the RAM is at 350Mhz @ 2.1v. It's DDR2-800, so I should be able to push it to 400 easily? Well, if I go up to 1500 FSB that puts the RAM at 375?
It seems that my system becomes unstable at 3.0 at 1:1, unless I place my timings at like 6-7-7-21. I've played around with them all, but that's the only combination I can use where Orthos can be ran for a significant amount of time without crashing.
Out of curiosity I raised the voltage on the RAM to 2.2 and was able to tighten the timings to 5-5-5-16, which is what the timings table in CPU-Z state for 400Mhz. I'm worried though about having the voltage so high without active cooling on the sticks. I do have an Antec 900 with 3 120mm fans maxed as well as the 200mm fan, so everything else stays relatively cool, but I'm still concerned, as if I fug these sticks, I'll be out of a working computer for a bit. :p
Any advice is welcome, I am quite a newbie when it comes to overclocking, so while I'm still confused, I'm still trying to learn all I can. :)
