kingston ssd 40 gig NOOB
johnzm
hey guys,
got the kingston 40 gig last night and ran hd tach on it and it looked perfect. and it was running the benchmark at the same speeds i see online. (230 meg burst and over 200 sustained across the disc)
i moved a few games to it to test it out, and after playing i ran hd tach again and it was nowhere near as fast and the results were not nearly as linear.
so i cleaned the drive in disk part, did a quick format and attempted again with the same slower result. after this i attempted a full format which made the drive even slower.
this is the result of the full format in hd tune pro
is there any way to get like new performance back? or will i have to wait for wipe tools from kingston?
who is gonna try the intel firmware on the Kingston drive first?
You can try AS Cleaner to write 1's to all free space. It's supposed to work by writing bits equating to "erased" into all the free space by creating a file, then deleting it. The contents of the file are left in the flash if you don't have TRIM, but the contents are equal to "erased", so it should have the same effect as TRIM.
I ran it on my X25-M, but the drive was basically new and I didn't do any extensive testing before or after. Quick HDTune measurements showed essentially the same performance new, AS Cleaned, and Toolboxed, meaning that AS didn't screw anything up majorly or anything like that.
