Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If you are asking if it will work in an nforce2 mobo, it will....but remember that technically the mobos don't offically support anything after pc3200, although pc3500 will work just fine, if you can get your FSB up that high.
Are you looking for suggestions for RAM or an nforce2 mobo?
