I just got a pair of Kingston HyperX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1200 (PC2 9600) Dual Channel Kit Desktop Memory - Retail. However, CPU-Z registers the speed at only at 400! I tried setting the motherboard to 1200, but it crashes and will not boot. I'm using a Asus P5E, which from what I'm reading in the manual supports Kingston HyperX 1200. I also tried manually setting the Ram Voltage to 2.3, but post picks up 1066 and CPU-Z still reads 400. What am I doing wrong? I would like to use the memory @ 1200, if its possible. I'm not completely familiar with the specifics on manually OCing it to the correct frequency.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134430
http://www.ec.kingston.com/ecom/con....asp?root=&LinkBack=&ktcpartno=KHX9600D2K2/2G
I'd appreciate any incite on the issue,
Thanks
Thanks
