Kingston HyperX 512MB BH-5
hadenn
Kingston HyperX 512MB PC3000 2-2-2-6 BH-5
140.00, its not a set price considering i dont know the cost of BH-5's
I might be interested, looking for something to match my current set. Will they do 215FSB @ 2-2-2-6? As the other poster asked, I would also like to know how you know they are BH-5.
0318 xxx lesser = 100% Winbond BH-5
0319 xxx greater = Winbond CH-5 or Winbond BH-5.
where do you find these stepping codes? I've only got the following:
9905193-024.A01
1344573 2.6v
ASSY in USA
Just curious, BUMP
(i know these sticks can do 220 @ 2-2-2-x, so i'm not particularly worried about it, but i'm curious :))
Originally posted by amd_man2003
I thought BH-5 was only in used in PC3200 and PC3500...
Limited runs were used in the KHX 3000, a lot of BH-6 stuff is used as well
You have to have peel off the heatspreaders. He was referring to the date codes on the actual chips themselves. I have a 256MB piece of KHX3000 that is BH-5. I've seen more BH-5 than BH-6 in these. Your chances now of finding BH-5 KHX3000 isn't very good. I grabed 4 pieces about a month ago. Only one was BH-5 based. The others were DW45 chips that didn't clock worth anything. DW50, DW60, or true BH-5 are the ones you want.
Also the non BH-5 chips will memtest to very high speeds as well. So be careful when people have not stress tested or Prime tested their KHX3000 chips that are claiming to be BH-5. You have to pull the heat spreaders to be certain.
Yea I got Some PC3000 KHX that runs Like it is in the Kentucky Derby Bought it for cheap awhile back that is the beauty of the the PC3000 HyperX 2226 1T But those timings will hold to PC 3500 level :)
