Has anyone got one of the King Mod kits? I'm considering getting one for my PC-A05N, but they are quite expensive for a few pieces of pre cut foam damping material, but I don't mind the cost if it does what it's supposed to.
For Lian Li PC-A05N
http://translate.google.co.uk/trans...-PC-A05N::13691.html&sl=de&tl=en&hl=&ie=UTF-8
& a UK supplier:
http://www.kustompcs.co.uk/acatalog/info_3390.html
http://www.kustompcs.co.uk/acatalog/Kustom_PCs_Shop_Sound_Proofing_39.html
- Is the quality good i.e. perfect shapes and edges?
- Is it effective i.e. noticeable drop in noise?
For Lian Li PC-A05N
& a UK supplier:
