kinda upset at Asus
xFuryofFivex
I bought the K8V-SE deluxe about little over a year ago... with 1gig of ram... not that games need at least 2 gigs...i thought ill get a gig to make it 1.5... then another gig to make it 2gigs even to replace the other 2x512mbs...
unknown to my knowledge is some odd thing that when anything over a gig is plugged in throttles down to DDR333... if i would have known that i would not have purchased this board..
i have emailed asus 2 times concerning this matter.. both times no reply.
anyone else have similar issues that couldnt be resolved by the manufactorer
i have tried other sticks of ram.. bios flashing,different slots, nothing fixed it..
It's not the board, it's your CPU. The Clawhammer series didn't support 4 sticks at DDR400.
read sir... "with 1gig of ram... not that games need at least 2 gigs...i thought ill get a gig to make it 1.5... then another gig to make it 2gigs even to replace the other 2x512mbs..."
get a gig to make it 1.5 then another gig to make it an even 2 gigs to "replace the other 2x512mbs"
if you have more than two sticks in at any time, it's gonna downclock. Period.
You just commented in the OP that anything over a gig downclocks.
EDIT: I see where the confusion comes from. My first comment was supposed to be "anything over 2 sticks downclocks". My bad.
ok thats cool dont worry about it.. i read it back and it seemed like it confused anyone
Lopoetve is correct. The A64 doesn't support more than 2 sticks of memory at DDR400 until you hit the Venice or newer cores no matter what motherboard you use.
Actually, the thread starter's CPU is a Socket 754 CPU, not a Socket 939 CPU. What's more, Asus is a bit strange in that two double-rank modules will run on their Socket 754 mobos at DDR400 (200MHz) - but three double-rank modules will be downclocked to DDR200 (100MHz).
That is a limitation of the memory controller on all Socket 754 CPUs.
Your best bet for 2GB is to leave the third slot empty, and just getting two 1GB sticks of PC3200 DDR memory.
Im using a ASUS K8NF4-E Deluxe. Socket 754 core. and its the same deal. Can only run 2 sticks of DDR400 or get it downclocked. Lucky ram is pretty cheap right now so 1g sticks arent to crazy expensive but it stings a bit when You have a couple nice 512s sitting there useless.
Nice how Asus's site makes no mention of the ram problem in their info on the boards. I knew about it going in but a lot of peep who dont read boards wouldnt.
Funny that I understood that you replaced your RAM with two 1GB sticks the first time I read it. Is there a newer BIOS for that board?
i got the board and later started reading these boards :(
