Aibohphobia
- Nov 16, 2013
^ What he said
I remeber that Aibohphobia told me there was a poll on wether to have the extra slot or not and that people voted yes.Since ive missed this i was wandering if many people voted yes to the extra slot and im the strange one for still not being convinced that is extremly necesarry?
I was actually surprised how many people wanted that extra slot, though I suspect a good portion of them just like the idea of possibly running SLI in the future but will just end up with a single card.
5 slots is a pretty big deal for me. Love the fact that this has it while still being so small. If I want ! card only I use itx.
It's worth going through the reasons as to why there's a fifth slot in the first place. Namely:
- For dual-GPU configurations, having a fifth expansion slot allows for graphics cards to be spaced by one slot, which considerably improves top-card temperatures.
- For those who want to have plenty of local storage, the room afforded by the fifth expansion slot allows for a 3.5" drive to be installed without blocking any PCI slots on the motherboard.
- If cooling or positive pressure is a concern, you can also install bottom-mounted fans without blocking PCI slots.
- A fifth slot makes a bottom-mounted radiator much more practical (assuming it fits across other dimensions), since it lends considerable vertical space before you start blocking PCI slots (you can block as few as one with a thin rad and fans). This is particularly good for AIO's.
- Finally, as few know what the future holds, the additional space and extra expansion slot provide flexibility for whatever hardware (and resultant configurations) someone might want down the road.
Interesting, looks like it'd be a great candidate for a nice little single-card WC setup. Might even be able to get away with a thicker bottom rad once you figure in the space savings of a full-coverage water block.
BTW, I've started in on thermal testing, trying out different fan, heatsink, and GPU combos. Started yesterday but I probably won't have time to complete it until this weekend.
Excuse the mess![]()
Here's the results from that poll: http://strawpoll.me/2993070/r
Every case should have USB ports. Nice concept so far though.
I would love to have the same color scheme as the prototype.
This brings up an interesting question, actually - what colors for what parts of Nova would you guys want, given total choice?
(What we'd actually be able to make would depend on available colors, MOQ, demand, and so forth, but I really just want to know what everyone's favorite color(s) or style would be)
[*]A fifth slot makes a bottom-mounted radiator much more practical (assuming it fits across other dimensions), since it lends considerable vertical space before you start blocking PCI slots (you can block as few as one with a thin rad and fans). This is particularly good for AIO's.
Isn't a top mounted radiator the most natural, though? Aside from blocking at least one PCI slot, a bottom one either needs dust filters at the bottom if fans are pulling in air from outside, or will work hard to push air out throughout the bottom if reversed. A top mounted one with fans pushing inside case air up through a radiator avoids dust problem, and encounters least resistance in terms of moving hot air. Would require a little more space at the top though. A radiator mounted at the back is also quite ideal, however, that would be a small one.
The radiator being mountable at the movable side plate with hinges is nice though, but depends on a movable part.
I'm no water cooling expert, just pondering a little.
Not sure what you mean about 'natural'. It's maybe because most case manufacturers have found this an easy place to add a mounting point for rad/fans. And common wisdom is that fans should blow the same direction as natural convection "to get the hot air out". Unfortunately, that last is untrue: a radiator which is fed warm case air is not performing optimally.
Fans should push fresh air from outside the case and through the radiator for best results. The ideal and what I would call 'natural' way to do this is, is an entirely separate radiator compartment like the Silverstone TJ07 or the CaseLabs radiator pedestals. That way fresh air is provided from one side of the case and warm air exhausted on the other side. But that is a bulky solution, unsuitable for SFF forum...
So a bottom, front or side radiator, with fans intaking is better for a small case like this. Dust filters would be needed wherever air enters the case. Or just regular cleaning.
There isn't room for a rad up top, there's barely room for a slim 120mm fan.
I was thinking though of changing the front 120mm fan mounting holes to vertical slots. We're considering some changes that would allow the PSU to shift up which would leave just enough room for some AIO rads in front with a SFX PSU.
Would be an interesting option for ITX video cards. Thoughts?
Also, what do you guys think of different colors for the frame?
[snip]
I like the color scheme. You could have the interior painted in several colors (red, green, blue, white, black) and have the exterior panels available in white and black. This would allow 10 color combinations on it's own.
As for the colors, I agree with Phuncz. 10-color combo sounds like a good meet in the middle. Maybe if there's enough interest you could do a premium run with custom colors or something. Personally I wouldn't mind something like a dark battleship grey frame with flat black panels. That'd look pretty sick![]()
Having an AIO cooler in front limits the GPU's length to how much ? It seems like a nice option, especially with the GTX 970 mITX cards and hopefully some future Radeon products too.
Excellent idea on the mounting holes. Very minor change to the design that opens a few more options.
Hey all, Aiboh wrote about Nova on the buildapc subreddit, and I think his post acts as a really great summary of the story of Nova, and of everything that's transpired on the forums. It's a fun read, chock-full of photos and nice anecdotal details that can easily get lost. Certainly worth a perusal for anyone that's been following the work on Nova, I think![]()
I think the support structure should be there for anyone that would want to add their own handle, but as can be seen in the poll the majority of people don't want to pay extra for the handle they might or might not even want in the first place.
I don't know how often a case like this is carried for long enough of a duration where the handle is needed but not the extra protection afforded by a bag or box.
The handle must stay, its been part of the package from day 1. I really want the handle. I use a handle frequently. I will pay extra or fabricate my own. At least leave the structural capability.
