veryrarium
- Apr 12, 2014
I see the idea behind the decision now. I thought the misalignment between the left (right?) side vents and bracket cutout may not look good in reality with some portion of the bracket surface showing up through the back portion of the vents, but due to the hinge taking some space shifting the bracket cutout backward would leave only a very thin vertical strip of metal in the back side portion of the bracket, so that is not good, I guess.The vent hole pattern on the panel is positioned to roughly line up with the holes on the top panel. There isn't anything at the front end of the rad bracket that needs venting.
1 The hinges I plan to use are high quality precision made stuff so I don't anticipate any issues there but that's what prototypes are for. If it turns out to be wobbly I'll drop it and go for screws on both ends.
2 It's not modeled but the plan is for the top and bottom of that piece to have a flange bent over 180 to stiffen the rail.
3 That's why the bracket is bent on each end. Sheet metal relies on perpendicular bends for strength, a flat piece of metal isn't that strong but with the careful placement of flanges it can support plenty of weight. But again, I'm using the prototype to test stuff like this.
Great to know these things have been thoroughly thought out. More reason to like your project!
