I have a PC PSU set-up so that the on/off switch is permanently bridged so that the power is always on. I use the on/off switch on the back to turn the PSU and the system on and off. I'd doing this because I'm using a customer motherboard that requires a special switch for it to power on, so I have to turn on the PSU first then the motherboard.
I've had 2 power supplies die on me and a friend of mine told me that it is because the customer board I am using draws too low power 40W max on a 500W power supply. Could that be true, I'm finding it hard to believe that a PSU can die for using too little wattage. Typically PSUs die because you pull too much current (e.g. shorts). My friend said it can't be that because all PSUs have fuses.
Is there a good PSU unit that can protect itself from temporary shorts?
