KG7-RAID Problem
runt
ok, i have an old kg7-raid and 1.4ghz t-bird that i'm trying to get running for a F@H machine but it will not post. does anyone happen to know the beep codes for said board so i can troubleshoot it? i know google is my friend, but i thought i would ask here first.
No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
One beep - board is working fine
One long beep then machine shuts down - faulty, improperly installed or missing CPU
1 short(Beep) System booting is normally
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM isn't inserted correctly
Short(Beep) continuous POWER supply has a problem
A two-tone siren, generally caused by overheating or out of specification voltages
Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
:D
thanks man. i will hook up a pc speaker to it in a bit (or tomorrow, damn gateway case doesn't have a pc speaker built in :()
