KG7-raid and AMX 1800XP
par0thead151
whenever i set the clock speed to 1800X133 my computer wont boot, and if i set it to 1000X100 it will work fine, but requires me to press F1 in order for it to pass the bios check on bootup...
it says the CPU is unworkable or damaged...
what is up?
this started happening after i took the CPU out when i was cleaning the HSF and re thermal pasteing the cpu.
did i shock my chip with static?
if so how come it still wokrsfine @ 1000 but not at 1800
anny adviceis appreciated,
thanks
clear CMOS, disconnect power. restore defaults to bios. upgrade to bios 5w. they are the most stable.
5w?
il update the bios tonight, thanks for the advice
i have already cleared the cmos, because when i set the clock speed to 1800X133 it wont go to the bios pre boot screen, it just sits there a blank monitor and the light on the monitor doesnt turn green like it usually does when i boot up
This is a dumb question but you did set the fsb to 133 right? Stock it's at 100. I had a kg7-r, never should have sold it, but remember I had a problem with that jumper with my first xp chip.
uhm, there is no 100 or 33 jumper. this motherboard is for all purposes CPU, JUMPERLESS
