Dark Prodigy
Jawbreaker
- Mar 10, 2006
Simple question here...
Going to be adding some ethernet wall plates and jacks in various places of my home. I like wired ethernet more than wireless. My question is which is better for a more solid signal..keystone jack or a simple coupler.
The coupler is alot more simple..no stripping wires and using the punchdown tool, just plug a cable to the back of the coupler and another into the opposite side... however you have to buy set cable lengths with ends already attached.
The jack you can customize your lengths of cable and not use excess, but of course you have to strip the ethernet wires and use the punchdown tool.
I'm not concerned about the amount of work, but I am concerned about which will give the strongest signal coming from my router in between keystones.
setup:
1 cable out from router into ethernet wall plate (into wall 1st keystone)
then from that keystone into another keystone downstairs (through/in wall)
then from downstairs keystone into media device (out from wall)
router----->keystone(in)<----------in wall cable---------->keystone(out)<-----media device
thanks.
setup:
thanks.
