Keyboard
boredguyatcomp
i suppose this isnt exactly case moding.
i want to paint my keyboard. i think spray paint is the way to go. i know the colors i want. but i need sugestions. i also want to paint the keys and put the letters back on them.
after the paint i would almost like to have a gloss coat or something that will keep the paint from coming off.
how would you go about doing this?
if you want the letters to look just like before the mod, you will need to silkscreen them on there. to accomplish this, just go to a local coating/paint/annodize shop and see if they can do it. they will charge you for the screen, which might be 3X5 inches and cost about 80$. the actual screening however is cheap, and wont cost much at all. Its cool because you can pick the font, size, color, and location of the letters on the keys.
