Grizzy said:go to your local computer store, buy the cheapest keyboard they have. cut into the wire, and check if the wires are the same colors. If they are, just solder the new end on
awdark said:If you want to... you can just use a multimeter and find whatever connects to pin 1 to the point in the keyboard and go from there... then just solder away from there and match the data you collected.
AMV said:hey tony, that would be wonderful...
(I have another one of the same type, but it's someonelse's so I don't want to crack it open)
awdark said:Have the chewed up stump left?
If you do, get a knife and cut that open... HOPEFULLY you will find some of the pins/colorful wires inside the insulated plug.
awdark said:it isnt too hard to solder to the bottom side of the pcb just make sure to use some flux..
put flux on (yes im obsessed with flux)...
