keyboard problem
gesicht
my keyboard is like 4 years old. i wanted to clean it so i took it all apart took all the keys off and cleaned everything. i put it all back togeather and now when i type it randomly shoots the cursor back to the start of the line.
also when i start the computer up it wont start untill i press all the keys on the keyboard a few times then it boots fine. it is like some key gets stuck down. i cant figure out what key it is that would cause the cursor shoot back the start of the line. if i knew what it was try and fix it. i took it apart again and made sure everything linged up just right.
any idea what key could be causing this?
sounds like the home button for one but I suspect more keys are at fault. sounds like your first time cleaning one. it can be tricky and requires a great deal of care depending on the keyboard. remove most keys and start adding a few at a time to test. it shouldn't be too hard to figger out the bad ones
if the keys have the small bars under the bigger keys they could be impropery seated...
g'luk
