Keyboard/Mouse Drivers for a mod.
JadedMaple
http://www.radioshack.com/product.asp?catalog_name=CTLG&product_id=26-534
• Uses the standard keyboard driver included with Microsoft Windows 98 or higher; refer to Windows documentation or online help files for driver installation instructions
http://www.londondrugs.com/Cultures...y=Keyboards&CS_ProductID=7220346&ProductTab=2
http://www.londondrugs.com/Cultures...tegory=Mice&CS_ProductID=7206410&ProductTab=1
Do you think any of those require drivers? A friend and I want to cut em up and stick some LEDs in over the break.
Think we will need drivers?
If you're running win98 or higher, I doubt it. No media keys, nothing special. Just plug and play.
Good luck with the mods. Think you'll paint the keyboards too? :) - only problem is that your keys won't be labeled anymore.
