Keyboard Modifications
LoserXLeet
Hi everyone. I'd like to lob off the right side of my keyboard (Everything after "enter"). Anyone know if this is possible without breaking the whole thing? Can anyone recommend a tried and proven method of doing this?
I haven't torn a keyboard apart recently, but I assume it's a continuous PCB under the entire keyset. Chopping off part of it can't be a good thing as who knows which circuit traces you'll sever. I think you'd end up with a pretty decent sized paperweight if you did this. As o0akoni0o mentioned, you'd be better off finding an existing version of what you need.
Well, I've tried buying one of those mini keyboards, but the keys aren't deep enough (I like the deep keys on old keyboards). Anyone know where I can get a small keyboard with big/deep keys?
Deck. I think they use deep keys in their small, LED back-lit keyboards. Also, DSI do some small, mechanical keyboards.
