Monkofdoom
- Jan 2, 2008
Hello,
I have recently been asked to solve a problem and to be honest I'm completely stuck, I have tried a few things and had no success. I'm hoping someone here may have a solution or have experience in this kind of modification and I would really appreciate your time and advice.
In short, I am trying to connect 1 mouse and 1 keyboard to multiple pc's (although the mouse is optional). In a perfect world it would be a PS2 connector on the keyboard although USB is ok if it is simpler.
Now I appreciate KVM switches exist but they do not do want I require, I need the keyboard to send it's inputs to all the computers at the same time, for example :
I have notepad as the active window on all the computers and type "xy2lk" on the keyboard, then "xy2lk" should be entered into notepad on all the pc's.
In total I need to connect the keyboard (and mouse) to 5 pc's and need a hardware solution rather than software, I'm wondering about modifications to the keyboard wire to connect 5 PS2 connectors but have no idea if this is possible.
Has anyone got any ideas ?
Thank you for your time,
- Monk
- Monk
