Keyboard dilemma
Hello all,
I am looking for a recommendation between two keyboards :
Razor Lycosa and Razor Arctosa (Silver).
Now, I don't need the keyboard to be illuminated. But I like the idea of having the extra USB port and the non-slip rubber finish keytop. On the hand, I have read somewhere that illuminated keyboards in day light or during the day are hard to read (I have been typing on a keyboard for more than 20 years, I know my keys now)
The black on black Arctosa is also hard to read in the dark.
I don't have a budget so I can afford anyone of them.
Basically, despire being illuminated, do you think the rubber finish and the USB port is worth the price difference?
thanks.
UPDATE : ok.. I swear I am not going for an illuminated keyboard, but I am also considering the Logitech Illuminated keyboard. I also like the design, just don't care much about LED backlighting..
..also... despite being very good keyboard, I am not looking into buying a G15... (I will buy a G13 soon though...)
what are you using it for?
well... I don't think I will be using it for gaming even though the main use for my system is gaming. (which I don't do as often as I would like to)
For gaming, I have a Logitech Rumblepad 2, a Belkin Nostromo n52 that I will be replacing soon with a Logitech G13, so I don't think I need a gaming keyboard per se...
Also, I am a programmer, but I don't do as much freelance as I used to, but I may have to work from home from time to time.
I have heard about the ghosting issues and keyblocking with the logitech... i don't know if in my case, I should be concerned.
Why not go mechanical?
actually, this requirement never really crossed my mind.
I had a laptop as my main computer for 18 months, so I am confortable with a scissor-switch type key.
I think I am also looking for a shorter key travel distance...
For typing purposes, I love my Logitech Illuminated. Very comfortable, especially for those who type for extended periods of time.
