Sorry for the long post, I tried to be detailed with all the info for the best possible solutions. Thanks for your patience.
So the computer has been running fine with no snags for a couple years now and yesterday I had done some major upgrading to the Software portion, Service Pack 1 on Win XP Pro.
Anywho, I dont think the Service Pack is the problem because all was running well after I did it all day as well as after several reboots.
I also have on my machine Norton Systemworks. Now I know a lot of you may or may not like it, but I have been running it for years with no problems. So anyway, today I was doing some routine maintenance as I have done in the past such as windoctor and disk doctor. It had been a couple weeks since I had done this and I figured since I shocked the system with the service pack it may need it.
Prior to doing the above, I had opened up Internet Options and deleted my cookies, temp files and internet history. I also went into the taskbar and start menu options in the control panel and deleted my recent documents.
Upon reboot I noticed in the recent documents menu that there were 2 items. Some reference to Quickbooks and another reference to Adobe Gamma Loader. Not sure why there were there as I have never seen them before. Both files ended with the extension .ink I deleted them out of the recent documents menu.
Finally, when I got all the above finished I rebooted the machine and when it came back up the mouse didnt work. (USB Logitech optical scroll mouse) Not only did the cursor on the screen not move, the infrared light was not coming on (no power?) I proceeded to use the keyboard commands to navigate into the device manager and sure enough it was in there and had the yellow exclamation. The USB devices were fine though. I found my driver install CD and reinstalled the driver and rebooted again. I got my mouse back!
I remember something about my mouse before and using the Logitech drivers that came with it having problems in Win XP, or perhaps I read about it somewhere, so I decided to go to the Logitech website and check for updates. I found a new driver that is supposed to work and be designed for Win XP, which was a newer version that the one I have. Needless to say I d/l the driver and proceeded to install. As the new driver was installing it recognized that I had previously installed Logitech drivers and was prompted that they be cleaned up before the new install could take place. I told the prompt yes to clean them up and proceed. After I did that I was told the system needed to reboot and then the install would continue.
Heres where the problem comes in. After the system rebooted the drivers did not continue to load, and my mouse and keyboard both did not work! The infrared on the mouse was working, so I know it has power and the lights on the keyboard work so it has power as well. I decided to do a hard boot since nothing else was working and I proceeded to hit F8 to get into the boot options menu. The first option I chose was Safe Made to see if I could roll the driver back, or set it to a Microsoft driver. As the Safe Mode boot loaded I found my self at the Windows log on screen and again my keyboard and mouse did not work, so I couldnt do anything again.
At this point I did another hard boot and proceeded to press F8 again to the boot options and this time I told the system to boot to a previously good configuration. Again, no mouse and no keyboard. After I had done that I rebooted again and hit my DEL key to go into my bios just to make sure nothing funny happened there. The PS2 mouse was set to auto and the USB funtion was enabled and everything else looked good as well. I have been in my bios many times and pretty much know all the settings and there was nothing out of the norm on this visit either. After looking in the bios I exited without saving since I didnt cahange anything and I rebooted again. No Mouse and No Keyboard.
I tried to reboot one more time into the boot options thinking perhaps I could boot into command prompt mode, but no dice.
I really seem to be stuck here and dont know what to do. Formatting at this point is not an option for me as I have too much data to lose on the drive.
Thanks for listening and please fire away the suggestions.
Craig
Craig
