kernel intrusion detected alert
dopple
My router is giving out the following alert in system log. whats this about?
kernel: Intrusion -> IN=ppp0.1 OUT= MAC= SRC=222.xxx.21.218 DST=59.xxx.100.xx LEN=40 TOS=0x00 PREC=0x00 TTL=108 ID=256 PROTO=TCP SPT=77 DPT=9064 WINDOW=16384 RES=0x00 SYN URGP=0 MARK=0x8000000
SRC=222.xxx.21.218 DST=59.xxx.100.xx ... PROTO=TCP SPT=77 DPT=9064
D-link router? Looks to be someone scanning your router. Notice the source and destination IP's and ports.
Unplug from the internet?
If you are connected to a world wide network, you are going to get scans. The important thing is to make sure the firewall is up and that you have no internet-facing open ports.
Run an internet firewall test (Shields Up) and if you pass, you should be ok.
its passing. thanks for the link. its a new router, hadn't seen these entries in my previous router..
