Kernal_stack_inpage_error?
Miller
For the first time ever, after my computer has suddenly restarted with a quick blue screen and then failed to recognise my HDD until I turn off my comp and just turn it back on, I could actually read the message and write down what it said.
The points of interest were:
0x00000077
And there was one long beep from my motherboard (not very loud).
Any insight? I googled it and it said it might be a result of defective hardware, but I'd like to not have to replace it (I finally got all my info on it after an unwanted reformatting). x_x
Any help appreciated. Thanks.
this sounds like your OS is totally corrupted. do a clean install and that'll clear things up real quick.
Well, this happened before I had to reformat. Is there anything else that may be causing it?
Should I just get a new HDD? :p
Also, is there a way I can reinstall my OS WITHOUT losing my data? ;\
One more thing, looking back on a previous post I made about this problem and a solution someone offered, I feel I should point out that this happens completely randomly, and I can go anywhere from a few hours to a few weeks before it happens.
Heh, another thing: I just used a Western Digital 'Data Lifeguard Diagnostics" program from their website, and it's called a WD-WCAEP1076404, it's 200gb, and according to the SMART disk info (whatever that is) everything checks out.
well... that means your hard drive is perfectly fine.
i have a list of three suspects:
(1) bad ram
(2) lousy psu
(3) borked kernel
I'll check out the first two...how would I figure out if I have a bad kernal?
Also, do you think it might be a bad RAM slot (DIMM or SIMM or whatever they are)? Would switching the RAM to different slots possibly fix the problem?
[Edit] Coincidentally, both my RAM and my PSU are made by Ultra. Maybe they're at fault. :p
Did you do the "Full Media" scan on your disk? That will tell you if your disk has any errors (bad sectors, I/O problems, etc).
Also, read this KB article. 9 times out of 10 this is caused by a bad block in the paging file. If this is the case, WD diagnostics should recognize it. If a bad block/sector is found, replace the drive.
Alright, I'll do a scan and figure it out.
Out of curiousity, what is the harm of a bad block in the paging file? Obviously there's the annoying random restarts, but since they can be fixed with a reboot, is there really any harm that can come from it?
Thanks for all of your help guys.
[Edit] Just ran a quick disk scan (didn't do the extended one), apparently it checked out (gave me a big ol' green check mark). I also clicked the other option (SMART information or something, not really sure), and that was green checks across the board too. I'm rather confused. I sent an e-mail to Western Digital as well.
Again, thanks for all of your help.
You'll need to do the full media scan to check for bad blocks. I think the quick test only does basic I/O tests and checks SMART (which is near useless).
