Vaulter98c
[H]ard|DCer of the Month - October 2009
- May 21, 2008
Based off the changes from fermi, do y'all think it'll do better or be like an ati card now?
It will be fun to see what they do.
I'm going to take a guess (and that's all it is) that it is about the same as a 580.
Also wonder if this will let PG come out with even larger GPU WU. (Have the client do a shader count test and request WU based on that)
After reading Anand's review, I think the theoretical max performance should be around 1.5 times GTX580. Not sure though...
true but AMD has proven theoretical and realistic performance are 2 different things even though the 7970 still wipes the floor against anything nvidia has outside of F@H.
Yeah, but AMD's case is about the coding (software) side of things as I said above. AMD's computing power is unfortunately not being utilized, and AMD is among those to blame if you wanted to blame someone. CUDA really makes a difference...
no i'm talking about other things outside of F@H.. AMD completely destroys Nvidia and its cuda when it comes to distributed computing(F@H being the exception) but their actual performance is still no where near the theoretical performance.
but given that GPGPU wasn't the priority of kepler my guess is its not going to be all that much faster then the 580 even with the shaders. but my reasoning for this is that they went the AMD way and are now running 1:1 gpu/shader clocks unlike previous generations. so great they increased the shaders to 1536 but they are now running at half the speed of the shaders from the gtx 580..
The comment about AMD cards simply isn't true, the only compute work that AMD cards before the 7 series were good at was simple hashing. Anything more complicated would suffer on their simple shaders, there just happens to be a lot of projects that aren't doing much more than hashing.
GTX680 will likely be slower at FAH than a 580 because of the fixed hardware scheduler. However GK110 should redeem the series with its CUDA centric design.
The shaders on 7000 series (GCN) are just as capable as the nVidia ones. On the older architectures using the wide VLIW designs it was quite a bit different. I just barely got some BOINC stuff running on my 7970, but I am kinda new to that stuff so I don't have anything to reference against.
I believe that's why he said "before the 7 series"... i.e. pre GCN cards.
Well, I'm seeing reports of a 680 doing 40k+ on certain WU.....
I'm wondering is anyone can confirm as I don't have one.
if thats the case i'm calling bullshit. there's no bloody way kepler should be able to do 40k PPD.
nvr mind, the guy got "confused".
I didn't think this was the case, and that's why I asked if someone could verify.
I don't think that's very true either since a 460 can't do 22k PPD. My 470 doesn't even do that. According to FAHMon my 470 is currently rocking out 15k PPD. (The WU it's working on it currently at 19%) Not sure how accurate it is.
meh. its got more shaders, but they run at half the clocks. as has been stated, they aren't built for GPGPU. the 680 has more in common architecturally with the 460 than the 580, so it might be best to adjust expectations based on 460 results than 580/570 results. I certainly don't expect the 680 to be a folding monsterI never said it was only using 384 shaders, only said 22k didn't seem that impressive to me. Currently I'm showing 17k PPD on my 470 GTX. I'd imagine a 570 or 580 can do more than 17k PPD.
If it does come to pass, it is going to be a huge wet blanket to everyone who jumped on the train early.
Kinda funny how the 680 might be similar to AMDs 62xx chips getting outpreformed in folding by the 61xx chips.
That would suck and I think I'm gonna hold off on buying the 6xx series cards now if that's the case. Granted I don't need the extra GPU power since my 470 handles what I need fine for now. Though if it did give a good boost in PPD, then that's a good enough reason for me. Looks like I'm gonna wait on IB to see how well it performs and just go with a CPU upgrade instead. Cheaper all around anyway.
