Keeping the Taskbar Hidden
ytry
Hello People
I have finally found a program that simulates the Mac OS10 doc in windows XP. My problem is I can't get the taskbar to stay hidden .
Dose anyone know of a reg hack or program that will keep the taskbar hidden .
Just to save time I already know how to auto hide the taskbar .
To auto hide the taskbar, follow these directions:
1. Right-click any blank portion of your taskbar.
2. Click on Properties from the menu.
3. The Taskbar Properties box will appear. On the Taskbar tab check the "Auto hide" box.
4. Hit the Apply button at the bottom right.
You just selected to auto hide your taskbar. This will make your taskbar disappear until you mouse over its location.
ytry said:
Hello People
Step 1) Put mouse over edge of task bar so that you have an up & down arrow.
Step 2) Drag taskbar downward until it's hidden.
Ice? He clearly says he already knows how to use auto-hide.
Hello People
http://www.hoverplant.com/easy.jpg
I do this plus I put it at the top of the screen. Works great as a prank when you take a screenshot of the desktop and people can't figure out why clicking Start does nothing.
yet another sordid case of caffine deprivation dyslexia :rolleyes: :p
sorry ytry
strange, ObjectDock does this automatically.... which prog are you using?
