Keep WaveMaster or get Stacker?
GaleForce
Dunno what to do I'm in a big dilema. I have a Wave Master right now, its very cramped inside due to my weird loop setup, even with the rad outside. Either way I'm getting Tygon tubing because I have a kinking problem, so the loop will get cleaned up a bit. Still, my pump is under my 3.5 bays and my res is in a 3.5 bay... they're pretty close together so I don't think I'll be able to neaten the loop and connect them. I'm looking at the CM stacker because it has much more room in it, but I don't know if I should stick it out with the wavemaster and figure something out. What would you do?
The Wavemaster is a great case. I would stick with it if you could.
However, I really like the look and functionality of the Stacker. If you can afford it.. and really want it.. upgrade. :p
Yeah I went with the stacker. I got a KICKASS deal for 200 bucks shipped on the Buy/Sell forums (stacker, crossflow, extra "4 in 3" bay, 2 rheobuses, and a TON of high end fans). Gonna drop 30 bucks on the side window, and hopefully sell my wavemaster for 140-150 with window and other stuff, and call it a day. :D
I actually like the Wavemaster. I dont need all that space and i dont really like the look of the stacker. But its still an amazing case, with all that space. Good for raid arrays and storage.
