Keep the 9800 Pro or not?
Seongmin
Well, I just purchased a brand new BBATI 9800 Pro for 95$ AR. I was wondering, should I return the card and spend more to get a 6800 or so? The specs on my computer are..
Duron 1.8 modded to XP2200@2.3 gigs
Shuttle AN35N Ultra
2 x 512 Mushkin Ram
Would the price justify the performance that I would gain for "upgrading" to a 6800 with my computer?
Garric, he doesn't have PCI-E.... He's using a 9800Pro, which means AGP.
If you can swing it, try for a 6800NonUltra(nu), which you can try to unlock to give yourself a 6800GT. But I think the bottleneck will be the CPU, because of type - it's a Duron.
