I just built a i7 system and I thought it was stable after minimal testing until I started getting blue screens after game installs. Specifically F.E.A.R. 2 and Rise of the Argonauts. Steam also caused me to blue screen. It also happens if I try to install Directx update.
blue screen says: error disk.sys and 0x00000050
here is my setup:
- Antec Twelve Hundred Black Steel ATX Full Tower
- OS: Windows XP 64-Bit
- GIGABYTE GA-EX58-UD3R LGA 1366 Intel X58 ATX Intel Motherboard
- Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920
- SAPPHIRE 100270SR Radeon HD 4850 X2 2GB 512-bit (256-bit x 2) GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
- CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit
- OCZ StealthXStream OCZ700SXS 700W ATX12V / EPS12V SLI Ready CrossFire Ready Active PFC Power Supply
- Two Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
I ran memtest (three instances simultaneously) overnight and after 400% - 500% it found no errors in my RAM.
Incidentally, Crysis WARHEAD installed with no problem and ran perfectly with all settings to enthusiast and antialiasing at X2. I played an hour or two before ending game myself.
Need help resolving issue(s). Will provide more info if needed. TIA.
here is my setup:
