Keep 930SB or upgrade to 2070SB?
chinese
Well after jumping on the $750 Dell 2001FP and playing around with it for a few hours, I've decided to go back to my Mitsubishi 930SB. I think the poor colors and screen door effect of the 2001FP gave me more eyestrain than the 'flickering' of a good crt. One thing I do miss is the screen size of the 2001FP so I'm thinking of upgrading to a Mitsubishi DP2070SB-BK to replace my Mitsu 930SB. For those of you who've used both monitors, would you say the 2070 is simply a bigger version of the 930SB? Reason being, I love the color reproduction and sharpness of text of my 930SB, and I was wondering if the 2070 falls short, matches, or exceeds the 930SB in these categories.
yea I've been using the 930SB for the past 7 months and love it, but I'd like a bigger monitor so I'm deciding whether or not to upgrade to the 2070SB or maybe dual 930SB's but that might look really awkward ^^
You could always get the NEC FP2141SB. It is 100% internally identical to the 2070SB and costs a smidge less.
