KDS Flat panel turns on then right back off.
sethmo
I have a KD Rad-7C 17" Flat Panel LCD and it just recently started to do this. I will turn the monitor on and the screen will turn on for about 3 or 4 seconds then it will turn right off.. The green light on the monitor still stays on. I bought a new power supply for it but it still does this. ANyone have any ideas? Could it be the controller card taht went bad?
How hard would it be to replace those to pieces? I dont even know what they are, but theres only 3 solder points total. Worth trying to find the right parts to replace them? I got the monitor for free so Im just trying to fix it to use :p
That's just glue holding down a couple inductors, nothing exploded.
Weird problem though. Have you tried calling their tech support? They might be able to tell you something, even if it is out of warranty.
Yah they just told me that its out of warranty and I would have to pay for shipping both ways for them to even look at it. So its just glue eh? What else could be causeing the problem, this is weird :confused:
