On my system build thread I posted HERE AreEss planted a seed of doubt concerning which Mobo I should go with.
After doing more research into the two boards, I am a still as torn as ever.
Newegg lists the K8WE as only having a 800mhz FSB HERE while some other random site I came across says it has a "Bi-Directional 16-bit 1000 MHz / 800 MHz." HERE Why the discrepancy between the two sites? How can you get the FSB to run at 1GHz and when does it only run at 800mhz?
The Supermicro H8DCE specs cleary state that it's FSB is 1GHz and if the K8WE only runs at 800mhz, the Supermicro clearly has an advantage right from the start. Not to mention you can find it for about $100 cheaper.
And lastly, if you guys wouldn't mind taking a look at this link HERE pgs. 22 and 23. Am I reading this wrong? Can you really just use one CPU and memory bank and then later add the second CPU and memory? Is it just that easy, or would I have to do some heavy reconfiguration after I installed the second CPU and RAM later? Also, is the Tyan board capable of doing the same. This would cut my initial build cost way down. I could just run one CPU and then later add the second. If K8WE can't do this, thats another point for the supermicro board IMO.
Thanks in advance.
Thanks in advance.
