normanbatez
- Aug 29, 2004
I got one of those k8v se from the amd retail program but I have seemed to run into a little problem with it. I would like to know what you guys think before I send the board back. When it came I hooked it up everything was fine. After about 4 weeks the computer quit booting so I ran through everything (reseating memory, video card), finally I pulled out the battery. The metal casing was cracked on the battery so I went over to an old system poppped out that battery and put it in boots fine. A week goes by, stops booting
. First thing I do is yank out the battery. Run to wal-mart (it was late only thing open) and buy a new one... everything is fine. A week goes by stops booting
. Pull the battery out again and this time I was prepared with a fresh one from best buy. Well its been like 4 weeks and no problems. The question is was it coincidence that 3 batteries went within a month (due to the fact that one was old and one was from wal mart) or do you believe that I have a serious problem on the board that is draining the batteries?
