k8n neo4 platinum/sli memory question/problem
kandor
Hi all,
I feel a little dense. I have have this MSI mb for about 3 months with an amd x2 3800+ processor and 2 x 1 gb of crucial pc3200 ram.
I installed a new hard drive yesterday and noticed *for the first time* that the ram was not running in dual channel mode.
It posted as 2 gb - DDR333, single channel 64 bit. I can't believe I didn't notice this before. The reason was I had both chips in the green slots which wont run double side memory sticks at ddr400.
So I moved one stick to purple the way the book says. Now the ram boots up as "DDR400 dual channel, 128bit"
The system runs winxp x64. Since I made this change the system has exhibited strange behaviour. eg. clicking the cursor to a new location while composing an email suddenly will result in a delay of 30 seconds with a busy cursor. Long waits upto 30 seconds for window to appear inside applications that ran fine yesterday.
Is there anyway that reconfiguring the ram could have fubar'd my system in some way?
PS: as a side note, my other system, (a p4 2.4 that has been oc'd to 3 ghz for 2.5years) blew a harddrive yesterday that was part of a striped array!!!!! It really happened - bye bye array!!!! Luckily I have backups but still, no more striped arrays for me.
See My Sig, I have The Same Mobo, Update to the 1.7 Bios, if you didn't do so already, Also, Check your Ram slots I'm betting you've Have one of your Ram Chips in the wrong slot Stick One In the PURPLE SLOT & Stick One In The GREEN SLOT, RIGHT Next to the OTHER ,& See If That fixes your Prob, Let Me Know What Happens, Hope that Helps :)
Hi - thanks for the info. I now have (as of yesterday) the ram in adjacent slots (1 green 1 purple). It's after I made this move that I'm seeing weird system problems. I will try the bios update and see.
Actually the newest BIOS is 1B and I have this board also (just the non sli/ultra version). Here is what the manual says about the double-sided:
Code:
The maximum memory speed decreases when the following two Memory Combinations is selected:
1. Each channel is installed with two double-sided memory modules.
2. Both DIMM1 and DIMM3 slots are installed with double-sided memory modules.
Mine are adjacent, in different color slots, being slots 1 and 2 or 0 and 1(not at my pc, just remember the numberings is consecutive, the ram is adjacent, and that I started with the lowest numbered slot).
Stripe and mirror if you really want striped performance and no fear of a drive failure. Tons of oracle databases out there on just that config.
I've got a vanilla 4 drive stripe, but all it has is my game installs. The actual game saves, config files, and my real data is sitting on 0+1.
I've got a job that runs every now and then, backup up the high performance array to the redundancy array. :p
